Salta al contenuto principale
Nikon D3100 cannot take pictures (Mirror stuck)
Cosa ti serve
  1. Nikon D3100 cannot take pictures (Mirror stuck), Describing the error: passo 1, immagine 1 di 2 Nikon D3100 cannot take pictures (Mirror stuck), Describing the error: passo 1, immagine 2 di 2
    • The camera was dropped and cannot take pictures. There is an error on the display when I am trying to take a picture.
  2. Nikon D3100 cannot take pictures (Mirror stuck): passo 2, immagine 1 di 1
    • Remove the lens by pressing the release button and twist the lens.
  3. Nikon D3100 cannot take pictures (Mirror stuck): passo 3, immagine 1 di 3 Nikon D3100 cannot take pictures (Mirror stuck): passo 3, immagine 2 di 3 Nikon D3100 cannot take pictures (Mirror stuck): passo 3, immagine 3 di 3
    • The camera house seen here is as it should be. I don't have any pictures of the problem, but i have illustrated it with the arrows. The small rubber dot was stuck on the side of the camera mirror.
    • I used a wooden rod (a soft material) to lift the mirror with very low force while trying to take pictures (The camera will try to open the mirror)
    • While slowly increasing the force to help open the mirror while still trying to take pictures the mirror released.
    • After reattaching the lens, see step 1. The camera worked 100% fine again :)
Conclusione
If the force you have to use become to large, contact Nikon to get a professional fix.
Altre 6 persone hanno completato questa guida.
2 Commenti
thank you very much. you help me
kotaro_higashi - Replica
I just got back from a Pro Camera Store where I was told that my mirror was not moving and the D3100 wasn’t worth fixing. Brought it home and gave ifixit a shot and 10 minutes later, I’m taking photos again! Your instructions were perfect, thank you!
johnwehrs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 6,460
