Salta al contenuto principale
Nikon D3100 Lens Mounting Ring Reseating/Replacement
Cosa ti serve
  1. Nikon D3100 Lens Mounting Ring Reseating/Replacement, Lens Mounting Ring: passo 1, immagine 1 di 1
    • Remove the 6 Phillips screws on the front of the lens mounting ring.
  2. Nikon D3100 Lens Mounting Ring Reseating/Replacement: passo 2, immagine 1 di 1
    • Carefully lift the mounting ring straight up.
    • Three unfastened metal plates lie under the lens mounting ring, be very careful lifting it up as to not disturb them.
  3. Nikon D3100 Lens Mounting Ring Reseating/Replacement: passo 3, immagine 1 di 2 Nikon D3100 Lens Mounting Ring Reseating/Replacement: passo 3, immagine 2 di 2
    • Reseat or replace the lens mounting ring and reassemble.
    • The locating pin on the right of the camera will help place the mounting ring properly.
    • The small metal plates marked in the image are not fastened and may displace if the camera if tipped or bumped. Be sure these are properly in place before reassembly.
Conclusione
Altre 9 persone hanno completato questa guida.
Taylor
Membro da: 01/30/15
1.189 Reputazione
5 Guide realizzate
USF Tampa, Team 16-6, Watkins Winter 2015 Membro di USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 4,178
