Salta al contenuto principale
Nikon D3000 LCD Screen Replacement
Cosa ti serve
  1. Nikon D3000 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Removal of the screws from the bottom will aid in the removal of the back as it loosens the bottom tabs of the camera back.
    • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove one 3 mm x 5.5 mm Phillips head screw from the bottom left of the camera bottom.
  2. Nikon D3000 LCD Screen Replacement: passo 2, immagine 1 di 3 Nikon D3000 LCD Screen Replacement: passo 2, immagine 2 di 3 Nikon D3000 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
  3. Nikon D3000 LCD Screen Replacement: passo 3, immagine 1 di 3 Nikon D3000 LCD Screen Replacement: passo 3, immagine 2 di 3 Nikon D3000 LCD Screen Replacement: passo 3, immagine 3 di 3
    • Gently lift the back of the camera off, starting with the top first.
    • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
    • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
  4. Nikon D3000 LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon D3000 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Use the black plastic spudger to push the black tab towards the lower ribbon. The black tab on the smaller ribbon should slide out of place.
    • Lift the white tab on the larger ribbon.
    • Gently disconnect both ribbons.
  5. Nikon D3000 LCD Screen Replacement: passo 5, immagine 1 di 2 Nikon D3000 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Remove six 5 mm x 4mm Phillips head screws , then remove the metal plate housing the LCD from the plastic camera backing.
  6. Nikon D3000 LCD Screen Replacement: passo 6, immagine 1 di 2 Nikon D3000 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Cover the old LCD Screen with tape before removing to avoid broken glass if the screen cracks during removal.
    • Use the metal spudger to detach the LCD screen from the metal plate that is held down by the adhesive.
    • Install new LCD screen
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team 14-7, Meier Fall 2015 Membro di USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Membri
6 Guide realizzate
2Commenti sulla guida
Completed this project but now my camera doesn’t turn on. Advice?
Eddie Martinez - Replica
My D3000 camera will not display. I change the screen but it still will not display pls help what will i do now
emmanuel nwokocha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 87
Tutti i Tempi: 11,738
