Introduzione
If your LCD screen cover is broken, damaged, or scratched, then you will find this guide beneficial. The camera will need to be partially disassembled in order to replace the clear cover that protects the LCD screen.
Cosa ti serve
Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
Remove one 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom.
Gently lift the back of the camera off, starting with the top first.
Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
Altre 5 persone hanno completato questa guida.
2Commenti sulla guida
Where could I find a new LCD screen cover?
You can find them on eBay.
