Salta al contenuto principale
Nikon D3000 LCD Screen Cover Replacement
Cosa ti serve
  1. Nikon D3000 LCD Screen Cover Replacement, LCD Screen Cover: passo 1, immagine 1 di 1
    • Remove three 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove one 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom.
    Chiedi a FixBot
  2. Nikon D3000 LCD Screen Cover Replacement: passo 2, immagine 1 di 3 Nikon D3000 LCD Screen Cover Replacement: passo 2, immagine 2 di 3 Nikon D3000 LCD Screen Cover Replacement: passo 2, immagine 3 di 3
    • Remove two 3 mm x 5.5 mm Phillips head screws from either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws above and below the USB port cover and above and below the SD card slot cover.
    • Remove two 3 mm x 4 mm Phillips head screws inside the SD card slot cover.
    Chiedi a FixBot
  3. Nikon D3000 LCD Screen Cover Replacement: passo 3, immagine 1 di 3 Nikon D3000 LCD Screen Cover Replacement: passo 3, immagine 2 di 3 Nikon D3000 LCD Screen Cover Replacement: passo 3, immagine 3 di 3
    • Gently lift the back of the camera off, starting with the top first.
    • Lift off the bottom slightly to expose the ribbon connector connecting the back of the LCD screen to the motherboard of the camera and lift the black tab on the ribbon connector.
    • Pull the ribbon away from the connector to disconnect the back panel from the main body of the camera.
    Chiedi a FixBot
  4. Nikon D3000 LCD Screen Cover Replacement: passo 4, immagine 1 di 2 Nikon D3000 LCD Screen Cover Replacement: passo 4, immagine 2 di 2
    • Remove six 5 mm x 4mm head screws, then remove the metal plate from the plastic camera backing.
    Chiedi a FixBot
  5. Nikon D3000 LCD Screen Cover Replacement: passo 5, immagine 1 di 1
    • Tape the buttons down on the front of the plastic camera backing in order to avoid losing them in the process.
    • Use a heat gun on the edges of the LCD screen cover in order to loosen the adhesive.
    • Use the prying tool to separate the LCD screen cover from the plastic camera backing (the LCD screen cover will come out towards the front).
    • Install a new LCD screen cover.
    Chiedi a FixBot
Conclusione
Altre 5 persone hanno completato questa guida.
Flor
Membro da: 08/26/15
300 Reputazione
Una guida realizzata
USF Tampa, Team 14-7, Meier Fall 2015 Membro di USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Membri
6 guide realizzate
2Commenti sulla guida
Where could I find a new LCD screen cover?
Aly Blackmore - Rispondi Condividi
You can find them on eBay.
Mike Roedema - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 84
Tutti i Tempi: 2,482
