Salta al contenuto principale
Nikon Coolpix S9700 Memory Card Replacement
  1. Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Nikon Coolpix S9700 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • Power off the S9700 and situate it so that it is upside down.
    • Place your finger on the compartment door.
    • Gently push toward the front of the S9700.
    • The compartment door should spring open by itself.
  2. Nikon Coolpix S9700 Memory Card Replacement: passo 2, immagine 1 di 3 Nikon Coolpix S9700 Memory Card Replacement: passo 2, immagine 2 di 3 Nikon Coolpix S9700 Memory Card Replacement: passo 2, immagine 3 di 3
    • Locate the memory card. Be careful not to mistake it for the battery.
    • Push down on the memory card until it won't go down further. Don't push too hard to avoid damaging your camera
    • Release your finger and the card will pop up out of its compartment.
  3. Nikon Coolpix S9700 Memory Card Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S9700 Memory Card Replacement: passo 3, immagine 2 di 2
    • Grab your memory card with two fingers.
    • Gently pull up and your memory card will come out.
Conclusione
USF Tampa, Team 9-5, Lacy Fall 2016 Membro di USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 511
