Introduzione
If your flash has become worn out from use and is not staying down, you might need a new flash housing. Performing this repair does not require a great deal of knowledge of the S9700, but will require a steady hand.
Cosa ti serve
Place your fingernail or a plastic opening tool in the space between the camera housing and the flash housing.
Carefully pry up on the flash housing. It will pop up automatically.
Altre 2 persone hanno completato questa guida.
4 Commenti
I dropped my coopix and cannot get it back in. Is there a way to replace the flash?
Dropped my Nikon Coolpix S9700 and broke the flash. It will not go back inside camera. Can it be replaced or repaired?
Does anyone know if it can be replaced or repaired?
I have done this to my camera. Cannot find replacement for flash. Can i use the camera as is?
