Salta al contenuto principale
Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide
Cosa ti serve
  1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 1 di 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 2 di 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 2, immagine 1 di 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 2, immagine 2 di 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Motherboard: passo 3, immagine 1 di 1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 4, immagine 1 di 1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 5, immagine 1 di 1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 6, immagine 1 di 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 6, immagine 2 di 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 6, immagine 3 di 3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 7, immagine 1 di 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 7, immagine 2 di 2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 8, immagine 1 di 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: passo 8, immagine 2 di 2
    • Pull the motherboard off of the main body of the camera.
  9. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: passo 9, immagine 1 di 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: passo 9, immagine 2 di 3 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: passo 9, immagine 3 di 3
    • Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
    • Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
Conclusione
Erik Knapton
Membro da: 01/30/18
222 Reputazione
2 Guide realizzate
Baylor, Team S2-G6, Johnson Spring 2018 Membro di Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 304
