Salta al contenuto principale
Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
Cosa ti serve
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 1 di 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 2 di 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, immagine 1 di 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, immagine 2 di 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team S2-G6, Johnson Spring 2018 Membro di Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Membri
10 Guide realizzate
1Commento della guida
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Brian Capouch - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 648
