Salta al contenuto principale
Nikon Coolpix S7000 Sticky Button Replacement
Cosa ti serve
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: passo 2, immagine 1 di 3 Nikon Coolpix S7000 Sticky Button Replacement: passo 2, immagine 2 di 3 Nikon Coolpix S7000 Sticky Button Replacement: passo 2, immagine 3 di 3
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S7000 Sticky Button Replacement: passo 3, immagine 2 di 2
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: passo 4, immagine 1 di 3 Nikon Coolpix S7000 Sticky Button Replacement: passo 4, immagine 2 di 3 Nikon Coolpix S7000 Sticky Button Replacement: passo 4, immagine 3 di 3
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: passo 5, immagine 1 di 1
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: passo 6, immagine 1 di 1
Conclusione
Shannon Beane
Membro da: 01/10/17
324 Reputazione
2 Guide realizzate
USF Tampa, Team S2-G3, Lacy Spring 2017 Membro di USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,482
