Salta al contenuto principale
Introduzione
This guide will show you the proper steps to take apart the back metal casing from your Nikon Coolpix S639.
Parti
Nessuna parte specificata.
  1. The battery compartment is located on the bottom of the camera.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Slide the yellow tab towards the back of the camera.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  4. Press the memory card down into the camera.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  5. Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  6. Carefully remove the back casing from the camera.
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  7. Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Conclusione
Anna Katrina
Membro da: 18/04/2013
1 Reputazione
2 Guide realizzate
Cal Poly, Team 8-56, Johann Spring 2013 Membro di Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 384
