Salta al contenuto principale
Nikon Coolpix S5200 Plastic Back Cover Replacement
Cosa ti serve
  1. Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: passo 1, immagine 1 di 3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: passo 1, immagine 2 di 3 Nikon Coolpix S5200 Plastic Back Cover Replacement, Plastic Back Cover: passo 1, immagine 3 di 3
    • Locate the left side of the camera
  2. Nikon Coolpix S5200 Plastic Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the two 0.1 mm screws using a Phillips Head screwdriver in order to properly open the camera
  3. Nikon Coolpix S5200 Plastic Back Cover Replacement: passo 3, immagine 1 di 1
    • Carefully lift the plastic back cover away from the camera
    • Remove the plastic cover from the camera
  4. Nikon Coolpix S5200 Plastic Back Cover Replacement: passo 4, immagine 1 di 2 Nikon Coolpix S5200 Plastic Back Cover Replacement: passo 4, immagine 2 di 2
    • Carefully push the rubber button cover up and out of the plastic cover
    • The plastic cover has been properly removed and is ready to be replaced
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 339
