Salta al contenuto principale
Nikon Coolpix S51c Lens Replacement
Cosa ti serve
  1. Nikon Coolpix S51c Lens Replacement, Back Cover: passo 1, immagine 1 di 2 Nikon Coolpix S51c Lens Replacement, Back Cover: passo 1, immagine 2 di 2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c Lens Replacement: passo 2, immagine 1 di 1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Lens Replacement: passo 3, immagine 1 di 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Lens Replacement: passo 4, immagine 1 di 1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Lens Replacement: passo 5, immagine 1 di 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 1 di 3 Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 2 di 3 Nikon Coolpix S51c Lens Replacement, Lens: passo 6, immagine 3 di 3
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Lens Replacement: passo 7, immagine 1 di 2 Nikon Coolpix S51c Lens Replacement: passo 7, immagine 2 di 2
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Lens Replacement: passo 8, immagine 1 di 3 Nikon Coolpix S51c Lens Replacement: passo 8, immagine 2 di 3 Nikon Coolpix S51c Lens Replacement: passo 8, immagine 3 di 3
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Conclusione
Ryan
Membro da: 04/12/11
155 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
2 Commenti
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - Replica
question: any source for lens block ? I can't find any on the internet
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,548
