Salta al contenuto principale
Nikon Coolpix S51c Back Cover Replacement
Cosa ti serve
  1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Back Cover Replacement: passo 2, immagine 1 di 1
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Back Cover Replacement: passo 3, immagine 1 di 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Back Cover Replacement: passo 4, immagine 1 di 1
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Back Cover Replacement: passo 5, immagine 1 di 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Conclusione
Ryan
Membro da: 04/12/11
155 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,290
