Introduzione
If the camera is not outputting any audio or the sound is muffled, then the speaker might need replacing.
  1. Slide the battery door open with a finger or thumb and release it so the door opens.
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Push the orange tab back and the battery will pop out.
    • Push the orange tab back and the battery will pop out.
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
    • Remove the single 2mm Phillips #000 screw.
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
    • Remove the two 3mm Phillips #000 screws.
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
    • Slide the speaker out from the bottom of the speaker piece.
Conclusione
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 32
