Salta al contenuto principale
Nikon Coolpix S3100 Camera Shutter Button Replacement
Cosa ti serve
  1. Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 1 di 3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 2 di 3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 3 di 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 2, immagine 2 di 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 3, immagine 2 di 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Shutter Button Replacement, Shutter Button: passo 4, immagine 1 di 1
    • Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
    • Be very carefully handling the spring as it could release from tweezer.
  5. Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 5, immagine 1 di 1
    • Gently remove the black adhesive tape.
  6. Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 6, immagine 1 di 1
    • Remove 2-2.90mm using a #000 Phillips screwdriver.
  7. Nikon Coolpix S3100 Camera Shutter Button Replacement: passo 7, immagine 1 di 1
    • The camera shutter is now apart.
Conclusione
Jorge
Membro da: 03/11/15
1.170 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 578
