Salta al contenuto principale
Nikon Coolpix S3100 Camera Lens Replacement
Cosa ti serve
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 1 di 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 2 di 3 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 3 di 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S3100 Camera Lens Replacement: passo 2, immagine 2 di 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S3100 Camera Lens Replacement: passo 3, immagine 2 di 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: passo 5, immagine 1 di 1
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: passo 6, immagine 1 di 1
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: passo 7, immagine 1 di 1
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: passo 8, immagine 1 di 1
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: passo 9, immagine 1 di 1
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: passo 10, immagine 1 di 1
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: passo 11, immagine 1 di 1
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: passo 12, immagine 1 di 1
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: passo 13, immagine 1 di 1
    • The lens is now separated.
Conclusione
Altre 11 persone hanno completato questa guida.
Jorge
Membro da: 03/11/15
1.170 Reputazione
7 Guide realizzate
6 Commenti
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Replica
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Replica
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Replica
I have same issue it shutter half opens and doesnt open correctly
shailendra - Replica
my LCD screen is stuck on white after after i did this :(
andrew welles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 62
Tutti i Tempi: 4,701
