Introduzione
When you are in a situation whether your LCD screen is malfunctioning, this guide will assist you to find the problem.
Cosa ti serve
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Altre 3 persone hanno completato questa guida.
4Commenti sulla guida
No mention of getting an electric shock while removing the case.Bit of a tingle anyway.I held the camera in a plastic bag after that.
This will probably not be replied to, but is there any reliable way to discharge the flash capacitor? Got shocked once, but I thought it was already discharged lol.
Connect a 1k ohm resister between the black and red wire from the capacitor. Give it a few moments to discharge through the resistor. Don't discharge the capacitor without a resistor as you run a good chance of destroying the electronics. Wear your latex gloves too.
Easy to follow
