Salta al contenuto principale
Nikon Coolpix S30 LCD Screen Replacement
Cosa ti serve
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: passo 1, immagine 1 di 2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: passo 1, immagine 2 di 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
  2. Nikon Coolpix S30 LCD Screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S30 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
  3. Nikon Coolpix S30 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the batteries by gently tipping the camera.
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
  5. Nikon Coolpix S30 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
  6. Nikon Coolpix S30 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Gently separate the back panel from the rest of the camera.
  7. Nikon Coolpix S30 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove screw connecting the top right of the screen to the mother board.
  8. Nikon Coolpix S30 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
  9. Nikon Coolpix S30 LCD Screen Replacement: passo 9, immagine 1 di 2 Nikon Coolpix S30 LCD Screen Replacement: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
  10. Nikon Coolpix S30 LCD Screen Replacement: passo 10, immagine 1 di 2 Nikon Coolpix S30 LCD Screen Replacement: passo 10, immagine 2 di 2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
Conclusione
Cassie Hamm
Membro da: 01/21/15
207 Reputazione
2 Guide realizzate
Penn State, Team 2-4, Kaschak Winter 2015 Membro di Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,086
