Salta al contenuto principale
Nikon Coolpix S230 Button Circuit Board Replacement
Cosa ti serve
  1. Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: passo 1, immagine 1 di 3 Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: passo 1, immagine 2 di 3 Nikon Coolpix S230 Button Circuit Board Replacement, LCD Screen: passo 1, immagine 3 di 3
    • Ensure the camera is turned off and the battery is removed.
    • Using a Phillips #000 screwdriver, remove the four 2-mm screws from the side of the camera.
    • Remove the two 3-mm screws from the other side of the camera.
    • Finally, remove the three 4-mm screws from the bottom of the camera.
  2. Nikon Coolpix S230 Button Circuit Board Replacement: passo 2, immagine 1 di 3 Nikon Coolpix S230 Button Circuit Board Replacement: passo 2, immagine 2 di 3 Nikon Coolpix S230 Button Circuit Board Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool into the seam where the front and back parts of the case meet on the bottom of the camera, and slide it along the bottom. Continue along the next side to separate the back part of the case.
    • If necessary, continue along the third and fourth sides until the case separates easily.
    • Lift the back off of the case.
  3. Nikon Coolpix S230 Button Circuit Board Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S230 Button Circuit Board Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully lift the LCD screen to reveal two orange ribbons connecting the screen to the camera.
    • Use tweezers to carefully lift the blue retaining flap holding down the orange ribbon cable. (Flap can be seen open in the second photo)
    • Slowly wiggle the ribbon cable back and forth while pulling away from the zero insertion force (ZIF) connector to disconnect the cable.
  4. Nikon Coolpix S230 Button Circuit Board Replacement: passo 4, immagine 1 di 2 Nikon Coolpix S230 Button Circuit Board Replacement: passo 4, immagine 2 di 2
    • Using tweezers, lift the black retaining flap holding down the larger orange ribbon cable.
    • Carefully remove the ribbon cable from the ZIF connector as before.
  5. Nikon Coolpix S230 Button Circuit Board Replacement: passo 5, immagine 1 di 1
    • Lift the LCD screen away from the camera.
  6. Nikon Coolpix S230 Button Circuit Board Replacement, Button Circuit Board: passo 6, immagine 1 di 1
    • Lift the button circuit board by gently popping it out of its connector.
Conclusione
Baylor, Team 3-1, Whitney Spring 2017 Membro di Baylor, Team 3-1, Whitney Spring 2017
BU-WHITNEY-S17S3G1
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 368
