Salta al contenuto principale
Nikon Coolpix S220 Battery and Memory Card Replacement
Cosa ti serve
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: passo 1, immagine 1 di 1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: passo 2, immagine 1 di 1
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: passo 3, immagine 1 di 1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Conclusione
Altre 2 persone hanno completato questa guida.
Shauna
Membro da: 04/05/11
798 Reputazione
5 Guide realizzate
Cal Poly, Team 12-32, Maness Spring 2011 Membro di Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Membri
10 Guide realizzate
Un commento
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 19,130
