Salta al contenuto principale
Introduzione
If the battery is dead or the memory card is full, it must be changed or charged. In order to accomplish either they must be removed. This guide will show the reader how to simply remove either one.
Strumenti
Nessun attrezzo specificato.
Parti
  1. Slide the battery and memory card cover (located on the bottom of the camera) to release it.
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  3. To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  4. To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Conclusione
Altre 2 persone hanno completato questa guida.
Shauna
Membro da: 05/04/2011
750 Reputazione
5 Guide realizzate
Cal Poly, Team 12-32, Maness Spring 2011 Membro di Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Membri
5 Guide realizzate
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 17,215
