Salta al contenuto principale
Introduzione
This guide will show how to access the motherboard which will give you the ability to remove the lens and flash.
Parti
Nessuna parte specificata.
  1. Remove the two 2.8 mm screws on the left side of the camera.
    • Remove the two 2.8 mm screws on the left side of the camera.
  2. Remove the four 2.8 mm screws on the right side of the camera.
    • Remove the four 2.8 mm screws on the right side of the camera.
  3. Remove the three 4.1 mm screws on the bottom of the camera.
    • Remove the three 4.1 mm screws on the bottom of the camera.
  4. Gently lift the rear cover from the camera.
    • Gently lift the rear cover from the camera.
  5. Skip the upgrade.
    Ottieni $10 di sconto su $50 con
    SKIPANDSAVE10
    Save Now
    Skip the upgrade.
    Take $10 off $50 with
    SKIPANDSAVE10
    Save Now
  6. Gently lift the screen out of its place.
    • Gently lift the screen out of its place.
    • You will need to hold the screen slightly above the camera because it will still be attached to the camera by an orange ribbon cable.
  7. Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
    • Use the tweezers to lift the ZIF connector which is holding the ribbon cables that connect the LCD screen to the motherboard.
  8. Slowly pull the screen from the camera.
    • Slowly pull the screen from the camera.
  9. Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
    • Remove the four 3.8 mm screws located near the bottom right and top left of the LCD base plate.
  10. Lift up silver LCD base plate
    • Lift up silver LCD base plate
  11. Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable. Slide the button panel ribbon cable out of its socket on the motherboard.
    • Using tweezers, lift up the retaining flap on the ZIF connector securing the button panel ribbon cable.
    • Slide the button panel ribbon cable out of its socket on the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Shauna
Membro da: 05/04/2011
750 Reputazione
5 Guide realizzate
Cal Poly, Team 12-32, Maness Spring 2011 Membro di Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Membri
5 Guide realizzate
It would be nice to have a guide for replacing the flash capacitor.
danwat1234 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,314
