Salta al contenuto principale
Nikon Coolpix P530 Battery Replacement
Cosa ti serve
  1. Nikon Coolpix P530 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: passo 2, immagine 1 di 3 Nikon Coolpix P530 Battery Replacement: passo 2, immagine 2 di 3 Nikon Coolpix P530 Battery Replacement: passo 2, immagine 3 di 3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: passo 3, immagine 1 di 3 Nikon Coolpix P530 Battery Replacement: passo 3, immagine 2 di 3 Nikon Coolpix P530 Battery Replacement: passo 3, immagine 3 di 3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: passo 4, immagine 1 di 2 Nikon Coolpix P530 Battery Replacement: passo 4, immagine 2 di 2
    • Gently remove the battery from the chamber.
Conclusione
Altre 3 persone hanno completato questa guida.
3 Commenti
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Replica
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Replica
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 3,709
