Salta al contenuto principale
Nikon Coolpix P510 Lens Casing Replacement
Cosa ti serve
  1. Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: passo 1, immagine 1 di 2 Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: passo 1, immagine 2 di 2
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  2. Nikon Coolpix P510 Lens Casing Replacement: passo 2, immagine 1 di 1
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  3. Nikon Coolpix P510 Lens Casing Replacement: passo 3, immagine 1 di 1
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  4. Nikon Coolpix P510 Lens Casing Replacement: passo 4, immagine 1 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 4, immagine 2 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 4, immagine 3 di 3
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  5. Nikon Coolpix P510 Lens Casing Replacement: passo 5, immagine 1 di 2 Nikon Coolpix P510 Lens Casing Replacement: passo 5, immagine 2 di 2
    • Unplug the two ribbon cables to completely detach the back.
  6. Nikon Coolpix P510 Lens Casing Replacement: passo 6, immagine 1 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 6, immagine 2 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 6, immagine 3 di 3
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  7. Nikon Coolpix P510 Lens Casing Replacement: passo 7, immagine 1 di 2 Nikon Coolpix P510 Lens Casing Replacement: passo 7, immagine 2 di 2
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  8. Nikon Coolpix P510 Lens Casing Replacement: passo 8, immagine 1 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 8, immagine 2 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 8, immagine 3 di 3
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  9. Nikon Coolpix P510 Lens Casing Replacement: passo 9, immagine 1 di 2 Nikon Coolpix P510 Lens Casing Replacement: passo 9, immagine 2 di 2
    • With the support screws out, you can simply slide the assembly out of the casing.
  10. Nikon Coolpix P510 Lens Casing Replacement: passo 10, immagine 1 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 10, immagine 2 di 3 Nikon Coolpix P510 Lens Casing Replacement: passo 10, immagine 3 di 3
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
  11. Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: passo 11, immagine 1 di 2 Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: passo 11, immagine 2 di 2
    • Remove five PH00 Philips screws with a Philips screwdriver.
  12. Nikon Coolpix P510 Lens Casing Replacement: passo 12, immagine 1 di 1
    • Separate the lens casing from the front.
    • The switch on the side simply slides off of the front casing.
Conclusione
Altre 3 persone hanno completato questa guida.
Brian Hulsey
Membro da: 03/31/15
1.506 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,285
