Salta al contenuto principale
Nikon Coolpix P510 LCD Replacement
Cosa ti serve
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: passo 1, immagine 1 di 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: passo 2, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement: passo 2, immagine 2 di 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: passo 3, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: passo 3, immagine 2 di 2
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: passo 4, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement: passo 4, immagine 2 di 2
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: passo 5, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: passo 6, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement, LCD: passo 6, immagine 2 di 2
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: passo 7, immagine 1 di 2 Nikon Coolpix P510 LCD Replacement: passo 7, immagine 2 di 2
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: passo 8, immagine 1 di 1
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
Conclusione
Altre 6 persone hanno completato questa guida.
Brian Hulsey
Membro da: 03/31/15
1.506 Reputazione
6 Guide realizzate
2 Commenti
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - Replica
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 6,016
