Salta al contenuto principale
Nikon Coolpix P100 Viewfinder Replacement
Cosa ti serve
  1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: passo 1, immagine 1 di 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Viewfinder Replacement: passo 2, immagine 1 di 3 Nikon Coolpix P100 Viewfinder Replacement: passo 2, immagine 2 di 3 Nikon Coolpix P100 Viewfinder Replacement: passo 2, immagine 3 di 3
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100 Viewfinder Replacement: passo 3, immagine 1 di 1
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100 Viewfinder Replacement: passo 4, immagine 1 di 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100 Viewfinder Replacement: passo 5, immagine 1 di 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Viewfinder Replacement: passo 6, immagine 1 di 2 Nikon Coolpix P100 Viewfinder Replacement: passo 6, immagine 2 di 2
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100 Viewfinder Replacement: passo 7, immagine 1 di 3 Nikon Coolpix P100 Viewfinder Replacement: passo 7, immagine 2 di 3 Nikon Coolpix P100 Viewfinder Replacement: passo 7, immagine 3 di 3
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100 Viewfinder Replacement: passo 8, immagine 1 di 1
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100 Viewfinder Replacement: passo 9, immagine 1 di 1
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100 Viewfinder Replacement: passo 10, immagine 1 di 1
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100 Viewfinder Replacement: passo 11, immagine 1 di 1
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100 Viewfinder Replacement: passo 12, immagine 1 di 1
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100 Viewfinder Replacement: passo 13, immagine 1 di 1
    • Now you have access to the camera's motherboard
  14. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: passo 14, immagine 1 di 1
    • Remove the screw that is located on the left of the view finder.
  15. Nikon Coolpix P100 Viewfinder Replacement: passo 15, immagine 1 di 1
    • Carefully detach the two ribbon cables and detach the viewfinder.
Conclusione
Altre 3 persone hanno completato questa guida.
Nghiem Ngo
Membro da: 01/15/15
330 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Tanski Winter 2015 Membro di USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 1,166
