Salta al contenuto principale
Nikon Coolpix P100 Display Screen Replacement
Cosa ti serve
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, immagine 1 di 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, immagine 2 di 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, immagine 3 di 3
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix P100 Display Screen Replacement: passo 2, immagine 2 di 2
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: passo 3, immagine 1 di 1
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: passo 4, immagine 1 di 1
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: passo 5, immagine 1 di 3 Nikon Coolpix P100 Display Screen Replacement: passo 5, immagine 2 di 3 Nikon Coolpix P100 Display Screen Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: passo 6, immagine 1 di 3 Nikon Coolpix P100 Display Screen Replacement: passo 6, immagine 2 di 3 Nikon Coolpix P100 Display Screen Replacement: passo 6, immagine 3 di 3
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: passo 7, immagine 1 di 1
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: passo 8, immagine 1 di 1
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: passo 9, immagine 1 di 2 Nikon Coolpix P100 Display Screen Replacement: passo 9, immagine 2 di 2
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: passo 10, immagine 1 di 2 Nikon Coolpix P100 Display Screen Replacement: passo 10, immagine 2 di 2
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Rikki Brown
Membro da: 01/09/15
267 Reputazione
2 Guide realizzate
USF Tampa, Team 1-1, Tanski Winter 2015 Membro di USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Membri
8 Guide realizzate
3 Commenti
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Replica
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Replica
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,063
