Salta al contenuto principale
Nikon Coolpix L840 Flash Replacement
Cosa ti serve
  1. Nikon Coolpix L840 Flash Replacement, Flash: passo 1, immagine 1 di 1
    • Press the flash button on the side of the camera to allow the flash to spring upward.
  2. Nikon Coolpix L840 Flash Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L840 Flash Replacement: passo 2, immagine 2 di 2
    • Unscrew the two black, 4mm screws with a Philips 000. (There should be one screw on each side of the camera).
  3. Nikon Coolpix L840 Flash Replacement: passo 3, immagine 1 di 2 Nikon Coolpix L840 Flash Replacement: passo 3, immagine 2 di 2
    • Remove the back case of the flash by lifting it off of the flash.
    • The back half cover has a little tail that keeps it locked in place. Wiggling the back cover around may help unhook the tail.
  4. Nikon Coolpix L840 Flash Replacement: passo 4, immagine 1 di 1
    • Push the flash inward to pop the flash out of its front case. Since the back case is removed, the flash should pop out from the back.
  5. Nikon Coolpix L840 Flash Replacement: passo 5, immagine 1 di 1
    • The see-through protective flash covering is stuck on to the flash with thin, double-sided tape. Pull apart the two components to access the flash.
Conclusione
Cal Poly, Team 1-11, Maness Spring 2016 Membro di Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,063
