Salta al contenuto principale
Nikon Coolpix L820 Settings Buttons Replacement
Cosa ti serve
  1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, immagine 1 di 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, immagine 2 di 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: passo 1, immagine 3 di 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
  2. Nikon Coolpix L820 Settings Buttons Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L820 Settings Buttons Replacement: passo 2, immagine 2 di 2
    • Next, remove the screw held on top of the camera above the Nikon logo.
    • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
  3. Nikon Coolpix L820 Settings Buttons Replacement: passo 3, immagine 1 di 3 Nikon Coolpix L820 Settings Buttons Replacement: passo 3, immagine 2 di 3 Nikon Coolpix L820 Settings Buttons Replacement: passo 3, immagine 3 di 3
    • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
    • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
Conclusione
Marc
Membro da: 03/23/15
430 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,354
