Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Is your flash not lighting up? This guide will show you how to replace the flash from your camera.
  1. Remove two 5 mm Phillips #000 screws below the flash component.
    • Remove two 5 mm Phillips #000 screws below the flash component.
    • In order to complete this step the flash must be open. To open the flash press the button located above the lens on the leftward side of the camera.
  2. Use blue plastic opening tool to pry open the casing for the flash.
    • Use blue plastic opening tool to pry open the casing for the flash.
  3. Remove the plastic casing surrounding the flash.
    • Remove the plastic casing surrounding the flash.
  4. Pull the wires connecting the flash out of the camera. Pull the wires connecting the flash out of the camera.
    • Pull the wires connecting the flash out of the camera.
  5. Unsolder the wires that connect the flash component. Unsolder the wires that connect the flash component. Unsolder the wires that connect the flash component.
    • Unsolder the wires that connect the flash component.
Conclusione
Altre 2 persone hanno completato questa guida.
Emilio Mena
Membro da: 14/01/2015
725 Reputazione
4 Guide realizzate
UW Tacoma, Team 3-1, Rose Winter 2015 Membro di UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Membri
8 Guide realizzate
It's not a comment, but where did you obtain the replacement flashbulb?
hgdddee - Replica
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
wildstreaksavannahs - Replica
I can't get into bulb
Szabolcs Demeter - Replica
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> n advmd vdsm vs ds m
nirik - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,647
