Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your camera is not turning on or reacting to anything you do, follow this guide on how to change the batteries.
  1. Orientate the camera so that the lens is pointing left. The battery door is located on the bottom of the camera. To unlock the battery door slide the switch on the battery door to the right.
    • Orientate the camera so that the lens is pointing left. The battery door is located on the bottom of the camera.
    • To unlock the battery door slide the switch on the battery door to the right.
    • Slide the battery door towards you and lift to open.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Remove four AA batteries one by one from the camera, making note of the proper alignment. Remove four AA batteries one by one from the camera, making note of the proper alignment. Remove four AA batteries one by one from the camera, making note of the proper alignment.
    • Remove four AA batteries one by one from the camera, making note of the proper alignment.
Conclusione
Emilio Mena
Membro da: 14/01/2015
725 Reputazione
4 Guide realizzate
UW Tacoma, Team 3-1, Rose Winter 2015 Membro di UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Membri
8 Guide realizzate
Great job...needed this
trimblefam38 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,560
