Salta al contenuto principale
Nikon Coolpix L610 Power/Shutter Button Assembly Replacement
Cosa ti serve
  1. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: passo 1, immagine 1 di 2 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Plastic Cover: passo 1, immagine 2 di 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: passo 4, immagine 1 di 3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: passo 4, immagine 2 di 3 Nikon Coolpix L610 Power/Shutter Button Assembly Replacement: passo 4, immagine 3 di 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Power/Shutter Button Assembly Replacement, Power/Shuttter Button Assembly: passo 5, immagine 1 di 1
    • Remove the panel containing the power and shutter button.
Conclusione
USF Tampa, Team 9-4, Brown Winter 2015 Membro di USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 745
