Introduzione
This guide is to show a user how to change a camera lens. One will need to take the camera completely apart. It is a pretty hard task but if one follow the guides it can be simple.
Parti
Nessuna parte richiesta.
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Aggiungi Commento
Remove the top (4.10 mm)  Phillips #00 screw adjacent to the battery compartment.
  • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
  • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
Aggiungi Commento
  • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
  • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
Aggiungi Commento
  • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
Aggiungi Commento
  • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
  • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
Aggiungi Commento
  • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
Aggiungi Commento
  • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
Aggiungi Commento
  • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
Aggiungi Commento
  • Remove the 6 (3.70 mm) screws on the metal cover. Two of those screws are covered by black plastic covers.
  • After removing the screws the panel should come off and will look like the final image.
  • Be careful of the red and black wires on the top. If the flash is charged you could get a mild shock.
Aggiungi Commento
  • Unplug the two ribbons for the lens. There will be latch that will need to be slid down. After loosening the latch, the ribbon should be able to be easily pulled out.
Aggiungi Commento
  • Remove the 3 (3.10 mm) screws that are located on the back of the lens cover.
The top and bottom red circles are obviously misplaced, those two screws are the other black ones below and to the left and right of the middle one.
xonoxf - Replica
  • There are two lens covers that will fall out after removing the back lens plate.
  • Remove the 6 (4.35 mm) screws surrounding the lens.
  • There are 2 more (3.70 mm) screws covered by a small black square located. Remove the black squares and proceed to unscrewing these final screws.
  • Remove the lens. It should just be free to pull it out.
It is not necessary to remove the six screws circled in red. To remove the lens unit, you just have to remove the two covered screws circled yellow.
xonoxf - Replica
Conclusione
Jeremy
Membro da: 21/01/2015
902 Reputazione
5 Guide realizzate
USF Tampa, Team 9-4, Brown Winter 2015 Membro di USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,578
