Salta al contenuto principale
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 2 Nikon Coolpix L340 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 2
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: passo 2, immagine 1 di 1
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
Conclusione
Altre 2 persone hanno completato questa guida.
Kelly Kryzak
Membro da: 04/12/16
140 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,642
