Salta al contenuto principale
Nikon Coolpix L330 Back Housing Replacement
Cosa ti serve
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: passo 1, immagine 1 di 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: passo 1, immagine 2 di 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: passo 1, immagine 3 di 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Back Housing Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L330 Back Housing Replacement: passo 2, immagine 2 di 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
Conclusione
Taibah
Membro da: 02/09/16
121 Reputazione
1 Guida realizzata
USF Tampa, Team 2-10, Cagle Spring 2016 Membro di USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 596
