Salta al contenuto principale
Nikon Coolpix L32 LCD Replacement
Cosa ti serve
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, immagine 1 di 3 Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, immagine 2 di 3 Nikon Coolpix L32 LCD Replacement, Front Panel: passo 1, immagine 3 di 3
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: passo 2, immagine 1 di 1
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: passo 3, immagine 1 di 1
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: passo 4, immagine 1 di 1
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: passo 5, immagine 1 di 1
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
Conclusione
USF Tampa, Team 2-4, Blackwell Fall 2016 Membro di USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 884
