Salta al contenuto principale
Nikon Coolpix L18 Lens Replacement
Cosa ti serve
  1. Nikon Coolpix L18 Lens Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Lens Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L18 Lens Replacement: passo 2, immagine 2 di 2
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Lens Replacement: passo 3, immagine 1 di 1
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Lens Replacement, LCD Screen: passo 4, immagine 1 di 1
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Lens Replacement: passo 5, immagine 1 di 1
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Lens Replacement: passo 6, immagine 1 di 1
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Lens Replacement, Front Cover: passo 7, immagine 1 di 1
    • Pry back the front cover of the camera starting from the right side.
  8. Nikon Coolpix L18 Lens Replacement, Lens: passo 8, immagine 1 di 2 Nikon Coolpix L18 Lens Replacement, Lens: passo 8, immagine 2 di 2
    • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
    • Remove the LCD base plate.
  9. Nikon Coolpix L18 Lens Replacement: passo 9, immagine 1 di 1
    • Gently pull the lens ribbon out.
  10. Nikon Coolpix L18 Lens Replacement: passo 10, immagine 1 di 1
    • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
  11. Nikon Coolpix L18 Lens Replacement: passo 11, immagine 1 di 1
    • Lift up the black and copper covering on the left side of the camera.
  12. Nikon Coolpix L18 Lens Replacement: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Pull the wiring at the top right of the camera away from the lens with tweezers.
  13. Nikon Coolpix L18 Lens Replacement: passo 13, immagine 1 di 1
    • Remove the cross-hair shaped wire cap to the left of the lens.
  14. Nikon Coolpix L18 Lens Replacement: passo 14, immagine 1 di 2 Nikon Coolpix L18 Lens Replacement: passo 14, immagine 2 di 2
    • Remove the 3 screws holding the lens to the camera frame.
    • Two 3.8mm black Phillips #00 screws on the sides of the lens.
    • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
  15. Nikon Coolpix L18 Lens Replacement: passo 15, immagine 1 di 1
    • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Andrea Govea
Membro da: 10/11/10
365 Reputazione
2 Guide realizzate
Cal Poly, Team 9-23, Regan Fall 2010 Membro di Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Membri
10 Guide realizzate
3 Commenti
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - Replica
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - Replica
.....okay but how do I fix it???
John V - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 17,366
