Salta al contenuto principale
Nikon Coolpix AW130 Shutter Button Replacement
Cosa ti serve
  1. Nikon Coolpix AW130 Shutter Button Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Shutter Button Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Shutter Button Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Shutter Button Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: passo 5, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement, Front Panel: passo 5, immagine 2 di 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Shutter Button Replacement: passo 6, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement: passo 6, immagine 2 di 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: passo 7, immagine 1 di 2 Nikon Coolpix AW130 Shutter Button Replacement, Shutter Button: passo 7, immagine 2 di 2
    • Using your thumb, separate the top piece of plastic from the camera.
    • If this piece does not come loose easily, try using the nylon spudger.
  8. Nikon Coolpix AW130 Shutter Button Replacement: passo 8, immagine 1 di 3 Nikon Coolpix AW130 Shutter Button Replacement: passo 8, immagine 2 di 3 Nikon Coolpix AW130 Shutter Button Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers from the precision tweezer set, carefully loosen the shutter button.
    • Atop the camera, there are two buttons. The shutter button should be the largest of the two.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,179
