Salta al contenuto principale
Nikon Coolpix AW130 LCD Screen Replacement
Cosa ti serve
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: passo 8, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 1 di 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 2 di 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: passo 11, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 11, immagine 2 di 2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Conclusione
8Commenti sulla guida
Hi.
Where can you buy a replacement screen?
Ben - Replica
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Replica
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Replica
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Replica
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,485
