Salta al contenuto principale
Nikon Coolpix AW130 Front Panel Replacement
Cosa ti serve
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Front Panel Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: passo 5, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: passo 5, immagine 2 di 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Front Panel Replacement: passo 6, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 6, immagine 2 di 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
Conclusione
Altre 6 persone hanno completato questa guida.
Un commento
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,528
