Salta al contenuto principale
Nikon Coolpix 995 Memory Card Replacement
  1. Nikon Coolpix 995 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 2 Nikon Coolpix 995 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 2
    • Set camera so the memory card compartment is facing you.
    • Place thumb under cover latch where it says "card", then gently lift straight upwards.
  2. Nikon Coolpix 995 Memory Card Replacement: passo 2, immagine 1 di 1
    • -Pull the memory card with your thumb gently .
  3. Nikon Coolpix 995 Memory Card Replacement: passo 3, immagine 1 di 2 Nikon Coolpix 995 Memory Card Replacement: passo 3, immagine 2 di 2
    • Be sure your memory card is facing the right direction, then gently insert it into the memory card slot.
    • After you properly reinsert the memory card, place your thumb on the top of the cover and gently press down until you hear and feel the cover click back into the closed position.
Conclusione
Cory Layman
Membro da: 10/04/11
89 Reputazione
3 Guide realizzate
UW Stout, Team 1-5, Zhou Fall 2011 Membro di UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,391
