Salta al contenuto principale
Nikon Coolpix 995 LCD Replacement
Cosa ti serve
  1. Nikon Coolpix 995 LCD Replacement, LCD: passo 1, immagine 1 di 2 Nikon Coolpix 995 LCD Replacement, LCD: passo 1, immagine 2 di 2
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Nikon Coolpix 995 LCD Replacement: passo 2, immagine 1 di 1
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Nikon Coolpix 995 LCD Replacement: passo 3, immagine 1 di 1
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  4. Nikon Coolpix 995 LCD Replacement: passo 4, immagine 1 di 2 Nikon Coolpix 995 LCD Replacement: passo 4, immagine 2 di 2
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  5. Nikon Coolpix 995 LCD Replacement: passo 5, immagine 1 di 1
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  6. Nikon Coolpix 995 LCD Replacement: passo 6, immagine 1 di 1
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
Conclusione
Cory Layman
Membro da: 10/04/11
89 Reputazione
3 Guide realizzate
UW Stout, Team 1-5, Zhou Fall 2011 Membro di UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,523
