Salta al contenuto principale
Nikon Coolpix 7900 Back Cover Replacement
Cosa ti serve
  1. Nikon Coolpix 7900 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 Back Cover Replacement: passo 4, immagine 1 di 1
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 Back Cover Replacement: passo 5, immagine 1 di 1
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 Back Cover Replacement: passo 6, immagine 1 di 1
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
Conclusione
Kaky Payne
Membro da: 04/17/12
121 Reputazione
5 Guide realizzate
Cal Poly, Team 12-38, Regan Spring 2012 Membro di Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,325
