Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the back cover.
  1. Remove the four 3.0mm screws on the bottom of the camera.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. APRI TUTTE LE SCHEDE
    Kit espansione RAM per Mac
    Acquista Kit
    Abbastanza RAM
    Per tutte le schede
    Acquista Kit
  4. Remove the two 3.0mm screws on the right side of the camera.
    • Remove the two 3.0mm screws on the right side of the camera.
  5. Carefully open the back cover. Take care as there are connectors still attached.
    • Carefully open the back cover. Take care as there are connectors still attached.
  6. Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  7. Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
Conclusione
Kaky Payne
Membro da: 17/04/2012
79 Reputazione
5 Guide realizzate
Cal Poly, Team 12-38, Regan Spring 2012 Membro di Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,036
