Salta al contenuto principale
Nikon Coolpix 5400 Battery Replacement
Cosa ti serve
  1. Nikon Coolpix 5400 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: passo 2, immagine 1 di 2 Nikon Coolpix 5400 Battery Replacement: passo 2, immagine 2 di 2
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: passo 3, immagine 1 di 1
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Conclusione
2Commenti sulla guida
I want to buy charger
MdYasir# - Replica
I have a changer but it is not working.please help me to charge it
MdYasir# - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 492
