Salta al contenuto principale
Nikon Coolpix 5400 Battery Replacement
Cosa ti serve
  1. Nikon Coolpix 5400 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: passo 2, immagine 1 di 2 Nikon Coolpix 5400 Battery Replacement: passo 2, immagine 2 di 2
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: passo 3, immagine 1 di 1
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 396
