Salta al contenuto principale
Nikon Coolpix 5400 Back Cover Replacement
Cosa ti serve
  1. Nikon Coolpix 5400 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove one 3.0mm Phillips #0 screw from the top of the case.
  2. Nikon Coolpix 5400 Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove two 3.0mm Phillips #0 screws from the card reader side of the case.
  3. Nikon Coolpix 5400 Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove four 3.0mm Phillips #0 screws from the bottom of the camera.
  4. Nikon Coolpix 5400 Back Cover Replacement: passo 4, immagine 1 di 1
    • Remove one 3.0mm Phillips #0 screw from the side of the camera.
  5. Nikon Coolpix 5400 Back Cover Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to gently remove the back case from the rest of the camera.
  6. Nikon Coolpix 5400 Back Cover Replacement: passo 6, immagine 1 di 1
    • Pull the back of the camera cover apart.
    • Connecting wires that are still attached to the back cover are fragile.
  7. Nikon Coolpix 5400 Back Cover Replacement: passo 7, immagine 1 di 2 Nikon Coolpix 5400 Back Cover Replacement: passo 7, immagine 2 di 2
    • Remove the two 4.0mm Phillips #0 screws holding the circuit board to the back case.
  8. Nikon Coolpix 5400 Back Cover Replacement: passo 8, immagine 1 di 1
    • Pull the LCD screen cables in the direction that the wires are exiting the circuit board.
    • Pull the wire connector gently, the plastic is very fragile.
  9. Nikon Coolpix 5400 Back Cover Replacement: passo 9, immagine 1 di 2 Nikon Coolpix 5400 Back Cover Replacement: passo 9, immagine 2 di 2
    • Pull the toggle wheel wire connector up and away from the top of the camera.
    • Pull the button control panel wire connector up and away from the top of the camera.
    • Gently remove the wire connectors; the plastic is fragile.
  10. Nikon Coolpix 5400 Back Cover Replacement: passo 10, immagine 1 di 1
    • Remove the six 3.0mm Phillips #0 screws holding the button control panel.
    • Remove the back cover from the camera body.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 419
