Salta al contenuto principale
Nikon CoolPix S5 Wrist Strap Holder Replacement
Cosa ti serve
  1. Nikon CoolPix S5 Wrist Strap Holder Replacement, Wrist Strap Holder: passo 1, immagine 1 di 1
    • Remove the wrist strap from the wrist strap holder by untying the string at the end of the wrist strap.
    • This will allow for the wrist strap to be pulled through the wrist strap holder.
  2. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 2, immagine 1 di 1
    • Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
    • This will cause the Battery/SD cover to pop open.
  3. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 3, immagine 1 di 1
    • Use the Phillips screwdriver to remove the four screws on the bottom of the camera.
  4. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 4, immagine 1 di 1
    • Using fingers, pull the silver side panels from each side.
  5. Nikon CoolPix S5 Wrist Strap Holder Replacement: passo 5, immagine 1 di 1
    • On the right hand side of the camera, remove the two screws from the wrist strap handle by using the Phillips screwdriver.
Conclusione
Altre 2 persone hanno completato questa guida.
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 35
Tutti i Tempi: 616
