Salta al contenuto principale
Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
Cosa ti serve
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 2, immagine 1 di 1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 3, immagine 1 di 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 3, immagine 2 di 2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 4, immagine 1 di 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 4, immagine 2 di 2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 5, immagine 1 di 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 5, immagine 2 di 2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 6, immagine 1 di 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: passo 6, immagine 2 di 2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: passo 7, immagine 1 di 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: passo 7, immagine 2 di 2
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
Conclusione
Altre 2 persone hanno completato questa guida.
Josh Miller
Membro da: 03/11/13
87 Reputazione
3 Guide realizzate
Clemson, Team 12-5, Benson Spring 2013 Membro di Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 465
